Create video with Mojave doesn't work
Verfasst: 11. Feb 2022, 20:56
Hello forum,
I have a problem with the video generator.
When I choose “create video” from the menu Export, the dialog box appears; I press the button to insert the name and the window proposing the directory appears.
As soon as I try to browse the directory or even write the name directly, the program goes to freeze and I am not able to unlock it in any way.
I must then force to quit and restart the project.
I have tried with various formats and frame rates but the result is always the same: the program crash.
This happens on the 2013 Mac Pro with Mojave System and with all the projects I have created with Wings X.
If I start the Mac Pro with Catalina system installed on an external disk the problem does not occur.
I also tried in a Mac Book Pro 2017 with Mojave and the problem is the same.
So I think it's related to OS 10.14.6
At the moment I cannot update the system to a newer version because I still use 32-bit software.
There is a solution?
Thank you
Daniele
Thank you
Daniele
